Loft "all guides should intersect with profile boundary
henri_bellanger
Member Posts: 4 ✭
I am designing a boat hull, it has a smooth curve (created with a spline) at the bottom and a sharp corner at the top.
I want to loft between the 3 faces i have created but the two upper line to not intersect with the opposite far side, is there a way to resolve this?
as you can see some funky geometry going on at the top there, when it should just be two straight lines and a hard curve
https://cad.onshape.com/documents/965d00636b4cff3c831b75f4/w/a429fce9c34442e3707ebcc9/e/98777789e5ab75d5236c4a8c?renderMode=0&uiState=6926f3d3d4504ac113985b3f
Matt_Shields
Member, Onshape Employees Posts: 896 PRO
It sounds like what you're trying to do could be done with two lofts.
+1 to @Matt_Shields comment
The underlying reason is that any single guide curve must consist of G1 (tangent) connected edges
cheer mate, thanks!
