Sketch - pattern a spline
jerome_goyetjerome_goyet Member Posts: 16 ✭✭
Hello,
does any one able to pattern a spline (linear or circular pattern) on a sketch ? all geometries work fine but the spline.
Any hints ?
Tks in advance
Jérôme
    edited October 2015
    @jerome_goyet , No because currently in Onshape pattern to spline entity in sketch is not available. You can raise ticket for this issue. We hope Onshape will provide this facility in future.
    Currently you can use work-around by making that spline to solid or surface then perform pattern operation by selecting spline part or surface and join them with the help of Boolean operation available in pattern.
    Yes I found that patterning a spline didn't work but haven't raised a ticket yet, might have to. @viru good workaround with the extrude surface but not ideal should be able to do this from the sketch.
  • ben_partouchben_partouch Member, csevp Posts: 158 PRO
    I see this was written in 20015, this is 2018 and I still can't pattern a spline.
    Am I missing something?
    Hi @ben_partouch
    You can help us prioritize this by voting on the associated Improvement Request:
    https://forum.onshape.com/discussion/7925/circular-pattern-a-spline
    In the meantime, can you make a solid or surface and use a Pattern feature rather than a sketch pattern?
  • scott_de_jongscott_de_jong Member Posts: 2 EDU
    It is 2022, and we still can't pattern a spline
  • dirk_van_der_vaartdirk_van_der_vaart Member Posts: 561 ✭✭✭
    No, but there is a simple workaround, draw a spline, pattern a number of points then copy- transform the spline.
    https://cad.onshape.com/documents/775d4d8c270bf1fb38b38fe4/w/8052c4056ff4766f9bd35828/e/fc6bb6f5f9a2eec0cf97a5f4
    You can also pattern an entire sketch, which can be helpful depending what you are trying to do...
  • S1monS1mon Member Posts: 3,957 PRO
    And you can pattern a curve. Make a composite curve from a sketched spline, and then you can pattern it.
  • Yann_Roth_91Yann_Roth_91 Member Posts: 7 ✭✭
    It's 2024 and we still can't pattern a spline... I'll try to open a ticket as it feels ridiculous not to be able to do this simple task.
  • will_briggswill_briggs Member Posts: 2
    Almost ten years later. I still can't pattern a spline. 😂
  • Cole_BeckhamCole_Beckham Member Posts: 1 PRO
    To be clear: ten years after this issue was raised, you want the users to continue filing tickets requesting a "feature" which is so utterly basic that its exclusion universally registers as, "I found a bug".
  • Ste_WilsonSte_Wilson Member Posts: 560 EDU
    To be clear.. You signed up just to say that?
