setProperty for appearance
graham_lockgraham_lock Member Posts: 265 PRO
Hi all,
I'm trying to set colours of some faces but it's not working.
The target faces already have an appearance set via the UI.
My code is of this form:
var theColor is Color = color(1, 0, 1);
setProperty(context, {
            "entities" : facesToColor,
            "propertyType" : PropertyType.APPEARANCE,
            "value" : theColor
Should the FS code override the UI appearances? If not is there a way to reset the UI settings such that the FS will work?
Thank you.
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 942 PRO
    Right-click the part, select Properties, click Reset All.
  • graham_lockgraham_lock Member Posts: 265 PRO
    Thank you but the Reset all button is disabled?
    Yeah, that's a weird one. Happens to me sometimes, too. I just type something random into the Description, hit Apply, then the Reset button comes back to life.
    That got it!
    Thank you.
