Improve standard content VS slots
Antoine_Boucher
Member Posts: 6 ✭✭
Hey there!
In most of my designs, I need to put slots to allow for adjustements when assembling the product once fabricated. In the assembly, I want to insert the necessary hardware to make sure I have all the bolts, rings, nuts, etc. I need. To do so, I use the standard content function of Onshape's assemblies, and this is where my issue is.
Inserting any standard content in slots is incredibly painful. When I select a face and click 'Insert', Onshape seems to not recognize the slots as holes in which to place screws. Even selecting the edge of the slots manually doesn't seem to work.
And so, I have to insert screws one by one.
Then I have to insert nuts one by one.
Then I have to insert washers one by one.
Then I have to insert the other washers one by one.
And so, what could take essentially 15 clicks instead takes over 60, not to mention the loading time for each unit of hardware I insert one by one. Unless, of course, I simply don't see and/or use the proper feature and complicate my life needlessly.
Could there be a new feature to the 'insert standard content' function that deals with slots perhaps?
Thank you.
Thank you.
I used to try and insert the hardware one 'type' at a time. Meaning I would put the screw, then replicate, then attempt to add a washer, at which point the replicate function would fail.
Seeing your reply made me realize that perhaps I was doing it wrong then, and after a little bit of trial and error, I realize that I must insert, say, a screw and a washer and *then* replicate it.
Thank you Eric, you will help me save a whole lot of time in the future!
This may sound like a complaint but it is a respectful product improvement suggestion - really. The insert/replicate functions of standard content into a surface needs to be more intelligent.
An example: Imagine a plate with many threaded holes. Half are 1/4-20 and half are 1/2-13. Inserting or replicating 1/4-20 bolts into this plate will result in all holes being filled with 1/4-20 regardless of whether they actually fit the holes and whether or not holes are already filled with 1/2-13 bolts. Of course, I could select each 1/4-20 hole individually but that would a lot of tedious work.
I just had an assembly filled with over 1,500 M8 bolts as a result of one mis-directed mouse click. The only action I could think of was to delete all 1500 and start over which cancelled an hour's work.
Since Onshape already knows the specifications of each threaded hole, would it be difficult to prevent bolts from being inserted into holes without a matching thread and preventing insertion into holes which already have bolts in them?
@bill_daniels
That does not seem right… The replicate feature only adds instances that match what the "seed" instance is mated to, if it's not behaving like this there something is going wrong, can you provide an example of the issue you are describing?
Unless you are clicking on a face with a bunch of holes when inserting components, which does in fact add instances to all circular holes, this inserts "independent" instances however, and is not the same thing as the replicate feature.
I was indeed clicking on populate face, but I didn't see another option.
