Somehow filter out default planes when using qEverything()
shawn_crocker
Member, OS Professional Posts: 975 PRO
I have a little customized delete feature that lets me delete from the part studio the inverse of what is selected. Sometimes I will import data and there will be alot of stuff in the part studio. So, I derive the studio into other ones and I use this inverses delete feature to select the parts I want to keep and delete everything else. Then I can sort of divide and conquer the large studio into smaller chunks for precise editing. I cannot figure out how to remove the default planes from the selection of qEverything.
shawn_crocker
Figured I might as well post my own answer here. Just found that this works
var allParts = qEverything(EntityType.BODY); const sheetParts = qBodyType(allParts, BodyType.SHEET && ConstructionObject.NO);
The "ConstructionObject.NO" was my missing condition.
shawn_crocker
Ends up this works(for real)
var allParts = qEverything(EntityType.BODY); const defaultPlanes = qUnion( [qCreatedBy(makeId("Right"), EntityType.BODY), qCreatedBy(makeId("Front"), EntityType.BODY), qCreatedBy(makeId("Top"), EntityType.BODY)] ); allParts = qSubtraction(allParts, defaultPlanes);0
I jumped the gun. 😂. That actually does not work.
var allParts = qEverything(EntityType.BODY); const defaultPlanes = qUnion( [qCreatedBy(makeId("Right"), EntityType.BODY), qCreatedBy(makeId("Front"), EntityType.BODY), qCreatedBy(makeId("Top"), EntityType.BODY)] ); allParts = qSubtraction(allParts, defaultPlanes);You might like my Keep Part custom feature, which I am realizing I never made a forum post about despite it being my first published feature. I'm gonna go do that real quick.
There we go. Posted and published.
Derek Van Allen | Engineering Consultant | MeddlerAlso see: defaultFeatures.fs for
qDefaultBodiesandqFrontPlaneetc.@MBartlett21 created his own "Delete part" feature a long time ago which has a "delete unselected bodies" toggle. I've used this for a while to do the same thing.
Thanks, I will test those functions
