Fix Importing Large Files
AuroraRonAuroraRon Member Posts: 138 PRO
I am experiencing constant import issues with Onshape when working with large files. Despite using Onshape for seven years, I have yet to notice any improvement in this area. I love using Onshape, but working with files that are not created in Onshape becomes very difficult or impossible. I would settle for just a shell, but parts with errors keep wrecking the complete assembly.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,933 image
    What format are you importing and which CAD system did it come from?
  • AuroraRonAuroraRon Member Posts: 138 PRO
    Inventor is one of them.  Supplier just tried again to export as a Parasolid and it just fails to translate.  I just created another support ticket.
    We also have no luck with step for engines, always errors that cause it to be unusable.  I have many examples from different engine companies you can try.
    After seven years....
    Your support ticket:
     "Failed to import parasolid"
    has been identified as a bug and we are working on it. As soon as this gets addressed and is pushed to cad.onshape.com, we will update this ticket to so you can confirm the update.
    Lets hope importing large assemblies finally gets some attention.  It really bothers me to see all the advertising trying to get solidworks customers to switch over and when you do, it takes seven years to address the issues with imports not translating correctly or failing all together.
    I tried to import another file today and waited two hours for Onshape to process only to end up with another unusable assembly.
    Does anyone know of a way to convert or import a Parasolid or stp file to one big solid or shell so that I can at least show something on a drawing?   It's been like this for every large assembly since I started here seven years ago and still nothing from Onshape.
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,035 PRO
    Have you tried importing in another CAD program? I keep a (free) hobby license of Fusion360, and if something does not come in clearly in OS, I try it in Fusion. I think "from memory of the last 3 years", anything that failed in OS also failed in Fusion.
    Thank you, Nick.
    The demos I've tried so far have file size limitations.
    After seven years of using Onshape, I still can't get any large file format to import into Onshape that is remotely usable. It does not matter who the source is. Will the importing from other formats ever be fixed?
  • lloyd_snelllloyd_snell Member Posts: 26 PRO
    I am currently trying to import a John Deere Engine - AH SNAP is the word of the day …. Nothing is working! How can I expect to design off-road equipment that will include several large imports, such as Hydraulic Pumps and motors, an Engine, Axles, Consoles, Seats, and other imported components? Can Onshape handle it?
    This engine model is so simple compared to the JD4 I am trying to import.
    I can tell you from almost ten years here, it’s an ongoing issue. What error are you having, perhaps I can help.
  • MichialAndersonMichialAnderson Member Posts: 7
    We have been having the same issue with aerospace composites. They will either fail the imports or take hours to import with faulty geometry. Has anyone found a work around. We are sent STEP files from our customers and it is coming mainly from CATIA
