Deleting points?
tj_thorniley
Member Posts: 65 ✭
NeilCooke
Moderator, Onshape Employees Posts: 5,991
Perhaps not as obvious on the mobile app. Press and hold two fingers so the box select pops up. Drag it around the point(s) to delete making sure only entities inside the box are selected then press the check mark to select them. Quick two finger tap to then bring up the delete menu.Senior Director, Technical Services, EMEA5
Make sure you've not got another feature pre-selected. eg, if you have the line tool selected and then right click on the point you will have context sensitive "line option" not the delete option.
Owen S
See:
This doesn't work either. Using the 'tilde' key does indeed list multiple elements, but selecting any non-line entity still doesn't delete the orphaned point. There needs to be a 'remove orphans' facility to do this; all 'orphaned' points would be highlighted for user inspection and then removed.
