Sweep on a conical spiral
Hello,
This problem is driving me crazy.
I would simply like to sweep a rectangle along a conical spiral and at the same time rotate it 90°.
If I use the sweep command, I can't control the amount of rotation (it can be 0° if I use lock profile direction, but it is not
what I want) ; if I use the loft command, the dimensions of the rectangle change along the path.
What can i do?
Than you very much
Mario
https://cad.onshape.com/documents/6f8c1deef0bc6e21c9efac94/w/3fd6b2402f5a89ca6d428fa5/e/6b76f7f2033a6836567f5ac3?renderMode=0&uiState=694c01dd26f810cdc934cffb
