How to bend a part along a projected curve
jason_ryan337
Member Posts: 70 ✭
Hi all. I would like to bend an ornate column along a projected curve on a curved surface. I have created a simplified column in the document below and would like to bend it onto the face of the bowl behind it. Is there a way this can be done reasonably? I would like to create a much more ornate column so drawing and extruding it directly on the curve face seems really hard.
If this method seems too difficult, could I instead start with an "unwrapped" flat surface of the bowl and add all of the columns to the flattened surface and then wrap the entire assembly back around the bowl (after writing this, it seems to have the same problem, lol)?
https://cad.onshape.com/documents/86202c50e42847587ee33ffd/w/cc0a2b38dd041a0c369d4ae0/e/1e40f934f2c900c897015652
if it’s on a bowl assuming it’s circular. Wouldn’t revolve be adequate?
There isn't a post forming process built into Onshape I am aware of. It should be possible to build the part based on geometry taken from the bowl, though, so it gets a shape that depends on and follows later edits to the shape of the bowl.
What you were asking for appears to be a sweet spot of mesh modelers.
https://cad.onshape.com/documents/ffca40e65fb929c1b8619e1d/w/6ad98b01057950bbc27b688f/e/ffea3638429a93dbcdee7548?renderMode=0&uiState=695a6d67a9c38288fe91b1c9
Hi there. I wish to make the column ornate which i think will be very complicated working on a curved surfaces in all 3 dimensions. I was hoping to make the part flat like I show in the image and then bend it afterward. The wrap command is awesome but only works on a cylinder. The work around to use wrap + move face + thicken for a sphere only seems reasonable for less complex features.
possible alternative? use split face and then move face. just tossing ideas.
Sorry if my posts seem out of order, there is such a lag in getting my posts approved. I don't understand why this forum requires mod approval of every post, it is very frustrating.
I really appreciate your taking the time to show a new example of making a simple column, it is very helpful. Eventually I would like to add flutes and inlaid beads so I will need to figure out how to do this, but maybe it won't be as bad as it seems.
I'd use the heck outta this feature if it existed! Maybe one day. For now it's modeling it that way or doing it elsewhere (Rhino, Plasticity etc) and importing.
Tween surfaces first, @EvanReese. I'm walking the long arduous road towards generalized freeform shape deformation one utility at a time.
Derek Van Allen | Engineering Consultant | MeddlerWoo seems like a hard road, but I will be grateful! Feels to me like we need the devs to expose some more Parasolid functionality and it'll basically make itself after that.
I'm actually curious how Plasticity has implemented it because I was combining through the Parasolid documents to try to find the FFD sauce and couldn't find the smoking gun of a utility that's being used.
Derek Van Allen | Engineering Consultant | MeddlerHi Evan, very cool that you commented as my hope for bending the columns is part of an effort to make a 3d printed bowl that has the exodus story blended onto the side of the bowl using your awesome new displacement map feature script :-)! In this version of the bowl, I used the image to generate the columns as well as the top and bottom rim features. After printing the images turned out pretty good given the resolution reduction to make the displacement map tolerable. However I felt like the rim features and columns could be much more crisp if I modeled them and would also remove some load from the displacement map.
I am still trying to figure out the best way to implement the displacement map as it didn't want to work with replace face and it was a struggle to figure out a way to make the new surface into a solid. Making it into something I can make an ornate rim feature will be the next issue to work through :-).
This is what I hacked together:
https://cad.onshape.com/documents/86202c50e42847587ee33ffd/w/cc0a2b38dd041a0c369d4ae0/e/5d1d576a3b3a058ef7b04761
Ah, i see. I do think that modeling the columns will be a better result. I'd sweep the main column part (or loft if taper is needed), then model the corbels flat and transform them into position at the ends. Then you could even do a different image per square if you wanted.
@EvanReese on the other hand, who needs Parasolid utilities when we can just borrow from my very good friends Sederberg & Parry?
WIP obviously.
Derek Van Allen | Engineering Consultant | Meddler@Derek_Van_Allen_BD 🤯 unbelievable! I strongly recommend taking a look at the functions of each of Rhino's deformation tools for inspo.
Ah to be a developer that can make tools that run without a feature tree, utterly unconcerned with build time. I'll definitely be stealing some inspiration from the Rhino UI for the final iteration of these tools but for now I needed direct control over all of my lattice points to prove some functionality. I think my next step is to poke at that Flex / Taper custom feature that's been floating around for awhile and rip out the surfacing core and replace it with proper FFD utils.
Derek Van Allen | Engineering Consultant | MeddlerI had to follow your breadcrumbs.
https://people.eecs.berkeley.edu/~sequin/CS285/PAPERS/Sederberg_Parry.pdf
And I asked ChatGPT deep research for more context:
https://chatgpt.com/share/695d46ea-b370-8010-b731-ac1344c180cb
Here are a few more foundational breadcrumbs to look at.
Derek Van Allen | Engineering Consultant | MeddlerI do wonder how extreme you could make the caching to make it more plausible. What's the least amount of work the feature could do if it has data cached somewhere?
@EvanReese I had a demo case with 45000 calls to a factorial function at one point and thought about yoinking your displacement map code and plugging it in to shove the Bernstein polynomial calculations into it. Will likely be implemented in the final versions of this feature but it's more important to work on things like surface stitching or knot insertion first before we go for performance boosts.
Derek Van Allen | Engineering Consultant | MeddlerOne thought I've had for easier caching that doesn't require much forethought is to literally cache the whole definition. You'd just have a hidden isAnything() param and shove the whole definition in there and return it. There might be some kind of extra step to prevent recursion or something.
Like a definition > old definition type thing? Could probably work.
Derek Van Allen | Engineering Consultant | MeddlerCould be great reasons not to, but I just mean something like.
definition.cacheDef = undefined;definition.cacheDef = definition;You'd still want to do some other calcs in editing logic and add them too and add them, but the cache could just be one big map o stuff. Thinking more on it now there may not be all that much utility in storing the whole definition, but maybe no big downside either.
@EvanReese Wheeeeeeeeeee
Derek Van Allen | Engineering Consultant | Meddler@Derek_Van_Allen_BD That's so cool I'm making involuntary disgusted faces! I can't believe how performant it is too! Wow wow wow
@EvanReese it gets cooler
Derek Van Allen | Engineering Consultant | MeddlerHi again. Was there a feature script for the FFD tool? It looks like you guys were making cool things, but I'm not sure if it's an available tool. Thanks!
@jason_ryan337 it's technically public since it's on my personal account and not my work one but I haven't posted it or finished making a version that has a clean enough UI to be happy with putting out there for people to actually put to use. I could make a thread for it in the featurescript forum and put out there as like a tech demo script to let the other developers get their fingers on it and make something out of it
Derek Van Allen | Engineering Consultant | MeddlerWait, what did I miss? Did @Derek_Van_Allen_BD find a way to flex parts??
RENDERCAD
Absolutely not. That would be crazy.
I found a way to flex surfaces
Derek Van Allen | Engineering Consultant | Meddler@jason_ryan337 @MichaelPascoe @EvanReese I've posted the script in this other thread I just started for people to play around with and for developers to make their own edits to. The current build is real janky and just a bashed together bit of vibe code to prove that you can do FFD lattice deformations in the first place but I'm unlikely to be able to put real dev time into a good implementation of this logic into a feature for awhile so for now this is what I've got. Go nuts with it.
Derek Van Allen | Engineering Consultant | MeddlerLol, awesome! I'm sure it's beyond my technical expertise, but may check it out. Thank you.
