Improvements to Onshape - January 9th, 2026
2»
  • EvanReeseEvanReese Member, Mentor Posts: 2,751 PRO
    @SkillCoach that makes perfect sense, and you're right, this kind of thing in Move Face would be a good solution. Off the top of my head, the workaround (other than looking up the face angle of a dodecahedron and hard-coding it) would be to create some kind of geometry (like a sketch) and use the Measure Value custom feature to get the angle as a variable.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,026 PRO
    I just noticed there is Measure command in drawings… and it has Dual Units!!
    When can we get dual units in the Assemblies and Part Studios???
