How to select edges easier?
troy_ostrander
Member Posts: 70 ✭✭
in General
Is there trick to select edges?
Not if you are in a tool that requires faces as input.
Usually, this isn't hard to do. It there someting else in the same place? Like a copy of the part, the face, a sketch? Then you might want to use the RMB menu and "Select other".
