Why doesn't Onshape support sketch blocks or sketch scaling?
mogplus8
Member Posts: 20 ✭✭
Just idle curiosity I guess. I've played with quite a few CAD packages, and most, if not all, support the concept of blocks for drawings. So why doesn't OS have this functionality? Is it on the to-do list?
Same comment for scaling sketch items. Several times I've found I wanted to create a copy of a group of sketch items, but make it a different size; 10% bigger, 25% smaller, whatever. I have not been able to discover a way of doing it. Well I have. I export the .dxf then import it into Librecad, and do the scaling and copying there. Not ideal but it's the only workaround I've found.
I'm not a power user or anything, just a hobbyist amateur. So maybe I'm missing something or just haven't explored OS deeply enough? Apologies if these are stupid questions.
One reason for this question is that I've recently acquired a laser engraver/cutter, and the software to drive it (I'm using Lightburn under Linux) can import .dxf files. Maybe OS isn't the right tool for this job and I should be using a 2D CAD package like Librecad, but I'm used to OS now and I'd prefer to do everything in OS, and it is perfectly capable of producing 2D sketches and exporting them in .dxf format. With these bits of functionality missing...
2
What sorts of things are you modeling that require sketch blocks and sketch scaling?
Perhaps there are some other workflows that would be even more efficient. If you're doing laser cutting, here are some useful things to know:
Laser Joint - custom feature that automates laser-cut finger joints:
https://cad.onshape.com/documents/578830e4e4b0e65410f9c34e/v/64dbc32dae444548a578ff56/e/dfd5effddfd7f2ecce4b0246
Auto Layout - simple layout tool for 2D cutting. Does not do nesting (uses bounding boxes of parts), but saves tons of time flattening things out:
https://cad.onshape.com/documents/576e01dbe4b0cc2e7f46a55d/v/731e73ac0b7b1e4334f13106/e/887d6e2324589bfd2058c3e1
Create drawing -> custom template -> no border or title block -> insert part studio filter -> select your part studio with the layout feature already run -> top view -> export as DXF -> ready to send to laser cutter!
Here's a video I made that features more info about how to use these workflows:
If you already have 3D parts generated for the formers or ribs, Auto Layout should be able to get things to a state where you can make the drawing of the part studio and export to DXF.
What I would recommend is rather than modeling formers and lofting between them to produce the body, instead try making the body as a surface loft and then modeling the formers within that body. That way, they will adapt if you need to tweak the shape rather than having to manually tweak them to get the shape you want.
Here is one approach for that method:
https://cad.onshape.com/documents/c0dfc369204d5486c422ba94/w/d266b880492ea06612a5418a/e/c0e89a8d475f794d3ef33108
As for writing FeatureScript, it's not as bad as it sounds! You can make one almost entirely just by clicking the buttons to prefill blocks of code. If you're okay with C and Python, then FeatureScript should not be too bad. I would recommend looking at some simple custom features to get a sense for how they work, such as multi-plane:
https://cad.onshape.com/documents/575857fae4b06a2590ec9d29/w/7a682d53abc1dbd6192f8299/e/5ac3fd64f34d310bc3e94a73
Plus, the documentation is great:
https://cad.onshape.com/FsDoc/index.html
great tips!
your 'Loft Section Demo' is not public. Did you mean to make it so?
mmm. that is working now. Maybe it was me...
@ian_harris952 I don't believe there's an IR for this for sketches yet. There's a similar one for drawings here:
https://forum.onshape.com/discussion/comment/35462
I'd love a "sketch block" that I can define once, and then configure a scale factor and be done with it.
I'll gladly vote for that!
This is how I have adapted an alternate way of accomplishing sketch blocks. If your looking to use sketch blocks as a way to visualize movement of components while sketching, it doesn't solve that problem. For me, I mainly use sketch blocks for standardizing different cutouts in material and such so this derived surface method works extremely well. In fact, I prefer it to solidworks answer to sketch blocks because the derived surface is forever linked back to the geometry that needs to fit the cutout and can be updated very easily.
One can only hope that this kind of functionality will happen eventually.
In my case, I often have to add our company logo to an object, and the best way to do that is with a scalable sketch.
You can also derive sketches in but they aren't free to move around, but you can use something like "super derive" to place a bunch of them at once if needed (having another sketch defining the locations can make this pretty quick). I guess if you could derive something in but make it "float" that would pretty much do it...
Depending what you are trying to do, you can also insert sketches in an assembly and that's the closest to behavior you will get to "traditional" sketch blocks, except that you are not in a part studio environment so you can't extrude them etc. If you make them into surfaces instead of sketch you can then create a context.
Basically nothing "quite" like a sketch block but there is some functionality that can get you pretty close (depending on what you are using the sketch blocks for)
We use sketch blocks to define major and common components such as the frame, elevator, climber, collector, wheels, motors, etc.
We can then create sketch layouts by placing the blocks and then adding 2D constraints. It is a great way to conceptualize and visualize motion without having to make 3D components initially.
Not having sketch blocks will definitely be a challenge for us to adopt OnShape.
However, we recognize the benefits of cloud storage, simultaneous editing, and improved file management, so we are going to give OnShape a try.
Regards,
Jerry
You should be able to do this by inserting and mating the sketches in an assembly. I guess it is might require a few more steps than throwing them in a 2d sketch, but it also means you can have 3D motion as well (with just 2D "parts") so it's also more flexible...
Switching to a more general plug for Onshape, I've been astonished how quickly new team members can master OS fundamentals using the self-paced curriculum that was rolled out in the past year or so. Good luck with your transition- you won't regret it.
Half way through a layout drawing and I asked the question online as to how to make a block in onshape - I always block out all my work, never redrawing anything twice and knowing that every single block will be identical and the most up-to-date version, whichever one I edit. I can then concentrate entirely on layout and not worry about what the final block will be, even after the architect changes his mind. I draw staircases with only an array and a block, with no regard for what the final finishes may end up being, as I would just have to alter one block whilst the workshop is already working on the carcass. I guess I could draw a part for an assembly but would that work with some of the mosaic-like designs I have to run around multiple faces of a restaurant, including disparate pieces of furniture? better read up on mates?
If you are doing floor plan layouts, one could argue Onshape isn't really the right tool…
However if you are placing multiple things and moving things around, an assembly of sketches is probably going to be your best bet. You can use just planar mates on your furniture while figure out where they go, and then lock them in later (by changing the mate to a fasten).
One you could leverage would be having your common types of furniture as configurations so you can change the size of a table or whatever just by changing its config.
I agree blocks would be a great additional bit of functionality. It would also be a real benefit to be able to make blocks, or at least group items in a drawing. Specifically I am trying to allow out team to quickly insert multiple tolerance blocks depending on the design requirements. The only work around I can find at the moment is to make a separate drawing which have the variants of the tolerance tables in it which are then copied to the drawing as required. I know these can be moved as a single entity, but there is no way to make it click into place or just manage as a single item.
I see this is an old topic, but I'll add this anyway . . .
One way to make a scalable sketch - Before you start, make a new variable called #glob (doesn't have to be glob, can be anything you like) and give it a plain 'numerical' value of 1. In my example, glob is short for 'Global Size Multiplier'.
Now, when adding a dimension to a sketch, you simply append * #glob (multiply by glob) to the end of that dimension, and do that same step for every dimension. Now, when you want to increase the size of that sketch in one step, you simply change the value of #glob to whatever you need it to be.
Working example - https://cad.onshape.com/documents/bf0c2a528a3a4b90310370e3/w/c0e12f354120b8802b4dfc61/e/63ee711de073138fa804ce2c?renderMode=0&rightPanel=variableTablePanel&uiState=6970fffdead6de81d89125fa
CADNurd's Linktree - find me everywhere else - https://linktr.ee/Liam.G
I've done this in the past. A bit cumbersome, but does work.
There is one point in time when a sketch can be scaled easily by just defining a single reference dimension: When it is imported (from DXF).
So, If I need a scaled sketch (for whatever reason, after all I live in a metric world), I just do my sketch and complete it as usual, then export the whole thing as DXF, and reimport it. I choose a dedicated mate connector as the sketch plane to import it to. Opon placing, I apply an appropriate dimension to set the scale. After that, I can put the mate connector wherever I need that sketch to appear. Usually only happens for logos and the like.
Definitely need sketch blocks!
If you guys aren't picky about sketch blocks living inside of the sketch solver there's a way I could see this working via a derive method in a custom feature.
