Modeling ACM (aluminum composite material) in Onshape
elijahpekaarelijahpekaar Member Posts: 12 PRO
edited January 19 in Using Onshape
Has anyone found a good workaround to model ACM? It is a flat sheet (.157" thick) that is cut with a V groove bit, leaving some material to bend and create a 90deg angle when bent up.
