need help creating object with differnt width/depth on all 4 corners
Hi All,
just started with onshape/cad drawing and need some help.
I needed to make a spacer for for a turbo airintake , and managed to make the right shape, but I just can´t get the depht/width right.
The object should have a different depht on all 4 corners, can anybody help?
https://cad.onshape.com/documents/0cf563a6e972bb49b7bb1646/w/e303f58da592e05b7d47f6fe/e/02a750de56f80b6b08f8da3f
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 905 PRO
    You could put mate connectors at the correct depth at 3 of the corners. Then make a plane and split the part.
  • robert_scott_jr_robert_scott_jr_ Member Posts: 743 ✭✭✭
    Hey Jack. The top surface is curved? The bottom surface is flat? - Scotty
