Joining 2 points across a perpendicular plane
benn_banks
Member Posts: 20 ✭
I created 2 semi circles on two parallel planes that are offset from eachother. I then created another plane across the flat sides of the Semi circles and im trying to sketch 2 lines from the outer points of the semi circles down that perpendicular plane. but the tool wont snap to the outer points, it will only snap to the center point of each semi circle.
My end goal is to create a sketch to loft from one sketch to this semi tube sketch.
What am i missing? or is there an easier way to do what im trying to do?
andrew_troup
Member, Mentor Posts: 1,585 ✭✭✭✭✭
@benn_banks
It is not possible to loft from a selected group of sketch entities which do not lie on a single plane
It is possible to loft from either a face (of a solid body) or a surface, even in the case where these are NOT planar.
However for what you're trying to do, it would be much easier to loft from a planar sketch (a round-cornered rectangle) representing the upper left boundary in your photo, lying normal to the camera film plane, and then (having made a solid body representing the outside of the shroud) cut out (using Extrude/Solid/Remove) the semicircular rebate where the shroud wraps around the cooling fins.5
If so you can make guide curve as below,
If above mentioned case is not you expected then please share your document or some snaps to understand more on your problem.
https://cad.onshape.com/help/#loft.htm?Highlight=loft
https://www.onshape.com/videos/lofting-in-onshape
When i made the loft i had to do a surface instead of solid, cause after, it wouldnt do a Shell from the solid. Then after the surface was formed i used the thicken tool, then extruded the circle to cut the slot out.
