Sheet Metal
robert_zschoche
Member Posts: 17 ✭
OptionsStuart_Tod Member Posts: 56 PRO@robert_zschoche ,
Onshape can't yet do sheet metal. I believe a request is 'in' for the capability.6
https://onshape.zendesk.com/hc/en-us/community/posts/202922330-Sheet-Metal-Features
What are the key sheet metal features or functions that are most critical to your workflow?
Thickness
Flatten
Flanges
Cut across bend/normal cuts
Convert surfaces to sheet metal
Stretch allowance (k-factor, or +material thickness rule of thumb)
Bend Radius
Stepped breaks (i.e. stepped cones/etc)
- Thicken from sketch (base flange)
- Flange/Contour flange, with the option to bend only a portion of an edge ("from" selector on both sides)
- Flatten with stretch calculations (k-factor mostly for me)
- Drawing flat view with bend axis reporting (print out all bend angles and positions)
- Proper cut support over bends
- Automatic corner seams (I mostly keep the same seam across bends)
- Mirror
- Pattern
- Chamfer/radius
- Convert solid to sheet metal
- Unbend
- Bend back (used often with punching)
- Emboss/punch
- Manual corner seams
I can be functional when functions up to (and including) item 6 are implemented.Nothing looks more like the ravings of a rank amateur than a drawing for a part from a thin material with lots of springback asking the operator to provide Bend Angles at the accuracy implied by "90.00 degrees". It's several orders of magnitude better than what's generally achievable, or what's needed.
I imagine Solidworks eventually addressed this but it was an irritant for many years, and in the meantime it degraded engineering mindsets by repeatedly suggesting to junior engineers that there is no such thing as specifying too much accuracy, and/or no such thing as implied accuracy.
I never really been in the habit of rounding in the 3d model, I always do it on the drawing. I notices in your challenge you specified to have the dimension rounded is this something you would normally do?
I want to be able to specify the number of decimals on the drawing, for bend angles.
For many years Solidworks did not permit this; flat pattern drawings showed all angles to two decimals of a degree and could not be truncated.
There are two topics here which are not quite the same thing: one is truncating the number of significant digits (and possibly rounding the last one up or down) and the other is shoehorning the dimension into a preferred number series. In the random challenge, it was a case of the latter.
I would certainly round (to a sensible "preferred number") the key dimension specifying a cosmetic feature, like chamfer or a radius, in a parametrically size-variable model, rather than in the drawing.
Drawings produced from parametrically variable models should manage themselves automatically, and only require human intervention if they go haywire (at least, that's how I see it).
Partly what drives "preferred number" rounding is because it helps make it obvious to everyone throughout the production chain that the feature does not serve any functional purpose which would require it to be an exact size.
CHF 1 x 45º has a very different implication for production and value engineering from CHF 1.414 x 50.2º
Furthermore, in many cases this class of cosmetic feature will be produced by standard tooling which will only be available in certain preferred sizes.
It doesn't make sense to me to have features on the model sized incorrectly with respect to the production drawing, or (another way of saying the same thing) to have the drawing showing a feature which is not to scale.
Another reason to get the model representing reality is that someone else may end up producing the drawing, and I don't believe in having lengthy and complicated handover briefings and notes: I reckon the model should guide the draughtsman as far as possible.
Is it worth renewing, as opposed to simply hopping off the upgrade treadmill, but keep using it for a few more years?
I think that will be trend. People will decide to get off the SolidWorks upgrades, and shift the money towards Onshape. They will then have 2 CAD packages for less than the cost of the old one. Call it a 2 for 1 deal. The change in SolidWorks subscription policy is causing some additional doubt among the users about how long they want to keep paying.
@jim_7 What is it specifically that is holding you back in sheet metal. Is it the whole sheet metal package, or just a biggie... like flatten? I'm curious.
Creating a new sheet metal tabs off an existing sheet metal part is the other commonly used tool also placing a bend in a flat sheet, these two features should be added ASAP
Here's a sheet metal project I did in Onshape, I used a very crude method to get a flat pattern. It went something like this 1. derive part to new studio 2. transform by mate connector to the origin and in the correct orientation (more for my drawing than dxf) 3. de-feature bend radius's with remove faces 4. split out flanges with split part, 5. transform the flanges via transform rotate, 6. boolean merge, 7. extrude remove to get edges normal 8. general clean up direct edit tools and extrude 9. export face as a dxf.
It would be nice to have a tool to do step 3 to 7 in 1 go.
CHF 1 x 45º has a very different implication for production and value engineering from CHF 1.414 x 50.2º AMS
