How to scale a sketch parametrically?
Hi all,
I am making a simple jewelry box, with the outline of a rose flower debossed into the lid. I created the sketch of the rose in Inkspape, and then imported the resulting .DXF into onshape. The sketch is very complex, lots of curves and vertices. I know that when you open a sketch, and it has no dimensions, that if you add a single dimension and then change that dimension, the whole sketch will scale accordingly. The problem I am having is that that only seems to work when the sketch is open for editing. If I add a single dimension to the rose that I am importing based on a parameter (I am trying to scale the size of the rose based on the outside diameter of the lid), then when I change that paraemter, then the sketch does not scale, instead it tries to pull the sketch apart, which causes the model to fail. So now I'm a bit lost. I figure that there must be a simple way to do this, but I'm afraid the solution is escaping me. Appreciate any tips. Cheers, John
Best way to do this is to create solids/ surfaces for what you want to do first and scale these instead.
Basically "delay" the scaling of that part until you are done with the sketch itself.
With the sketch open, go to the 'transform' tool, then box-select the entire sketch - a triad-thing should appear - grab the diagonal triangle and pull it outwards and upwards - a dimension box should appear letting you input a scaling factor.
Unemployed Onshaper- Operating on European time - More of me here ➤➤ https://linktr.ee/Liam.G1 -
Thanks very much for the reply. The question is how do you make that parameter-driven? AFAIK, the sketch transform tool is a one-time operation.
Thank you for the reply. This is what I ended up doing.
Yes. You're right, a one time operation, which - for some reason - doesn't accept variables. If you search the forum for discussions on 'Sketch Blocks' and why Onshape doesn't have them, you might pick up some tips/advice.
Unemployed Onshaper- Operating on European time - More of me here ➤➤ https://linktr.ee/Liam.G0 -
P.S. - Gave ChatGPT a go at the 'Missing Sketch Blocks' mystery and learned a thing or two . . .
The issue is that a single dimension won't reliably scale a complex imported DXF sketch once its geometry becomes constrained. A better approach is to keep the rose sketch unconstrained and use the Transform feature with the Scale option to resize it parametrically. Link the scale factor to a variable calculated from the lid diameter and the rose's original size. This avoids forcing individual curves and vertices to move independently and helps prevent sketch failures.
"then the sketch does not scale, instead it tries to pull the sketch apart, which causes the model to fail."
Another way to do this is to draw vertical construction lines outside and left and right of the flower and make them coincident to points (tangent to curves can also work if need be) that are at the extremes of the flower. Make the distance between the two lines the dimension you want the flower to be. - Scotty
