I'm new to CAD. What workflow should I use to create this roof jack?
michael_moore728
Member Posts: 3 ✭
I need to create a part similar to the image. What would that workflow look like? I'm very new to CAD. I've done most of the tutorials on here, but I think I may need a loft. Any pointers would be a big help.
For instance, in you OP, it might be that the left end has a slightly concave silhouette when you look across the loft. If so, the left guide curve would need to be curved to match.
But if your guide curves are straight lines, you will often get by without them, particularly if the two profiles have the same number of entities
That is not the case here, and that's probably why viru, who definitely knows what he's doing, included guide curves.
