Part Naming and tabs
berkeley_spencer
Member Posts: 13 ✭
I'm sure this has been asked before but i don't know how to describe a search.
Anyway... i wondered why the tab and the part you created doesn't change together when its renamed and also when you add a part to an assembly you get both options.
Which one do you choose as i cant tell if there's a difference.
Sorry if its been asked before.
Options3dcad Member, OS Professional, Mentor Posts: 2,470 PROOnshape has multipart studios, that means you can have multiple parts is same part studio. In assembly, you can insert the whole studio with one click or browse independent parts from each studio and insert one by one.
If you only have one part in each tab, there is no difference.
Inserting whole part studio is just 'batch insert' and any parts created to that studio after inserting will not be automatically placed into assembly.
Example below, I have made frame and wheels in same part studio tab. Assembly insertion let's me choose to insert the whole thing with one click or use parts independently. If I choose to insert multiple parts that are already positioned in part studio then I can select them all and use group mate to keep them positioned relative to each other. This is very handy.
//rami5
