Server Capacity
Is anybody else having problems Loading Data for the Onshape servers. I have been waiting over 5 min for a Part Studio to open. I also have problems when in Drawing with the lag before things appear on the drawing. The problem is not my download speed (76ms) I have also tested the speed on other websites which works fine. Or is this a standard speed for all Free users.
Graham
Graham
Second, our servers are not overloaded. We monitor our servers 24x7 and my team responds to any performance problems we detect. We can add capacity around the globe in minutes.
Having said that, you should not be seeing those performance problems, so something is not right. Please open a support case (via "Feedback" in Onshape) and we will work through the issue with you.
End-user quality of service is very important to us. Once you submit the ticket and document, our ops guys will look into it.
Thank you for your support of Onshape.
Graham
Thanks for your comment, yes I do have adblock as an extension on my browser. I will disable and give it a try, I will post with the result.
Thanks
Graham
Is anyone else having similar problems with Drawings, I am thinking now I have a problem in the way I have built the Model which may be the root cause of the problem.
I have submitted a feedback to Onshape so will keep you all informed on the outcome.
Graham
You should get best results with firefox or chrome, I've had good experience in dedicating one browser (chrome) to Onshape and use another (firefox) for other browsing. So Onshape window is the only instance I have open when modeling.
If my experience of similar problems is any guide, there may be other Chrome extensions causing you problems.
Try disabling them all, and see if that resolves it. Then you can at least go about finding out which ones are rogue.
Anyone who would like to test my Document for errors, message me with your email address and I will add you to the Share, sure would like to prove what is the problem, if it is my Document I may be able to find an answer to the problem.
Only time I have seen that 'Page unresponsive' -message was when I played with 8000 pieces part studio a while ago:
https://forum.onshape.com/discussion/comment/10858/#Comment_10858
Thanks for sharing your document. I can reproduce the slowness. And I've seen WebGL crash a few times. Honestly, it's pretty nasty.
I do not think it's your model. I believe your model is fine.
We're debugging the problem now and hopefully will have some sort of answer for you shortly.
Thanks -Bob
I was able to reproduce your problem with a large part I created (a linear pattern of cubes with cylinders between them) and then showing hidden lines in my ISO and front views, as you have done. The combination of the two things hits a scalability problem in drawings as it is now.
As a workaround for now, could you hide hidden lines in your views when you're working in the drawing? If you hide hidden lines in your views while you're dimensioning and working in the drawing, I think you'll find the speed is much improved. Then if you need to show hidden lines to print or release the drawing, you can do that at the end.
I realize this is not great. We need to improve the performance and scalability of drawings to handle such cases.
Thanks -Bob
Graham
