How to place a part exactly horizontal in an assembly.
lars_andersson
Member Posts: 20 ✭
I have missed how to place parts exactly level in an assembly so they come aligned to vertical and horizontal in the drawing.
Now I rotate them so they look okay by eyesight, I do not think the parts snap to exact position.
There seems to be no planes in assembly?
matthew_menard
Member Posts: 96 ✭✭✭
Will using a mate connector to the origin work for you? Like so:
The block was originally rotated randomly in space and using the revolute mate connector in the direction I wanted got it back aligned with the origin. I'm assuming the revolute mate connector aligns the axis initially, but may be wrong and I just got lucky. Now, how this movement will affect the rest of your assembly, I can't say. At least the undo button works well though.
8
When you insert it from the part studio, it will come in orthogonal to the viewing axes, and you need to "Fix" it.
refer this video
https://www.onshape.com/learn/essential-training-series#!lesson-number=4&title=assembly-basics
starting about 1m
Any parts you mate to it will automatically be horizontal and vertical to the standard view directions.
Great mate tip, mate! (we cross-posted, which is why I didn't acknowledge in my earlier post)
Presumably in most cases a "Fastened" mate to the origin would be the most desirable choice ?
