Save the units-settings? Export a dxf?
Hi!
For every new drawing i had to set the units from inch to mm! How can i save my unit-settings?
2. Question: How ca i export my file to a dxf?
Thank you everyone!
Thank you everyone!
andrew_troup Member, Mentor Posts: 1,585 ✭✭✭✭✭
1) Look up "Help", under "Templates". If you don't want to use a custom template, you can choose the Onshape-provided templates, making sure to choose "ISO", which has the units in mm
2) Presuming you mean a drawing file, here's what Onshape Help has to say:
5
Question 2.
With 'file' I assume you refer to your drawing. Export can be done from RMB menu on drawing tab.
You can also export sketch to dxf with RMB on feature list:
