Assembly section view
lucymarie_mantese
Member Posts: 24 ✭
I am having trouble creating a section view for my assembly and would appreciate help. I have attached a screenshot that hopefully gives an indication of my approach. I generated a mate connector and brought up the associated coordinate axes. I think I'm supposed to click on the plane or arrow direction that I want to make the section cut. I am interested in sectioning in the x or y directions but the only direction I am able to section-cut is in the z direction. Thanks for any guidance.
You need to edit that mate connector in origin so that you get the direction you wan't. Use move / rotate 90deg and change 'rotate about' -axis.
Then just choose that mate connector and section view from view menu. You can change distance and angle from triad which appears in section view.
ps. Just noticed that it is not possible to select origin as entity from feature list, I will create a ticket for that.
1). You have to rotate the manipulator for the required axis. or
2) Rotate the mate connector to keep z-axis of mate connector to required axis while creating mate connector
This workaround with having to find a face and then rotate the view 90 degrees is cumbersome.
i've created a simple dummy Cube that I now load as a part in my assembly that i can click to create the basic section views in 1 click.
It's public: feel free to add it to your assembly as a simple work around untill the Onshape team comes up with a better UI solution for creating the base section views.
https://cad.onshape.com/documents/39fb7b5a9f9514ef090f38e9/w/1218400f029cd405adfe9076/e/994a7bc158f136f4b21eb43c
Vote for these:
https://forum.onshape.com/discussion/16948/cross-section-through-origin-by-default
https://forum.onshape.com/discussion/17033/cross-section-through-sketch-plane-without-selection
https://forum.onshape.com/discussion/20469/using-view-cube-as-shortcut-for-standard-sketch-planes
