Application can request purchases on your behalf & write access???
pow
Member Posts: 6 ✭
With the 3d pdf Exporter what would I be agreeing to if I authorized it?
Says: Application has write access to your documents
I'm not comfortable with that behavior and if some cad-app ask too much before I can see if I even need it, I will skip - like I did with 3dpdf app.
Please require exact explanation why some app needs any further access and try to keep it minimum. IMHO.
To give some perspective on why an app might need a grant, here is a rough overview;
If an app would like to let you sign in to a unique account associated with your Onshape id, it will ask for access to your profile.
If an app would like to be able to access even as much as the current document, it will need read-access (this is 99% of the apps)
If an app would like to create a new tab to store results, it will need write access. An integrated app per se does not need write access.
If an app has a pay option accessible from within the app (eg purchase an upgrade or purchase a consumable (eg runs, hours, cycles), then it will need billing rights.
I personally review the grant requests and if they are beyond the needs of the app, i ask the authors to delete the request.
Hope this helps
Joe
