Evenly spaced dashed lines on a multipart model
daniel_chow
Member Posts: 108 ✭✭✭
Link to the document
Hello everyone,
Thanks in advance for answering my questions, I'm on vacation and spending much of it learning this awesome tool called onShape, maybe you heard of it?
So I have a multipart model, I've started a new sketch on a cylindrical object. The entities of my new sketch have evenly spaced dotted lines. So they are not construction lines. From what I understand from this and this information I found, the dotted lines show sketch entities that are obscured by other parts.
Ok I get that but I am not able to revolve extrude my new sketch. Any ideas here?
Alright here's what I'm trying to do. Linear pattern a coarse thread down the length of the shaft. Here are the parts: vase, jaw and shaft
Here is the problem. I used the "use" tool in my sketch, double checked that the sketch entities are connected. You can see it turns into evenly spaced dashed lines.
And here's the problem. When I go to try revolve/extrude it, can't select the sketch entities..
Hello everyone,
NeilCooke
Moderator, Onshape Employees Posts: 5,980
Hi Daniel, it's probably because the part face is in the way. You should either RMB > Select Other, or quite often what I do is hide the parts which are obscuring the sketch, select what I need to, then unhide the part again before pressing OK so the part is used in the merge scope.Senior Director, Technical Services, EMEA1
Here is the solution in greater detail for anyone else wondering how to do this:
When sketch entities is obscured by a part you will see an evenly dashed line. An UNEVEN dashed line is different, those are CONSTRUCTION LINES. Simply hide the part that is obstructing the sketch entity. THe dashed lines will become solid because they are not longer obstructed and you can use those entities to extrude.
Go ahead and make your extrusion, in my case, I am revolve / extruding.
Now make the part that was interfering with your sketch visible again. You will see interference, then use the boolean tool to remove. Or in this case, to make this vise model i'm trying to copy, you need to repeat that new part using the linear pattern tool and then use Boolean tool to remove all the parts.
