Lost assembly feature list
LumenLumen Member Posts: 16 ✭✭
edited July 2016 in Community Support
I have lost the assembly feature list. Maybe it has been moved "offscreen". Is there a hotkey to enable/recenter ?
    If you are working with browser version, I don't see any other way to lose feature list than browser zoom.
    Check that your browser zoom is 100% and if that is not the case try to refresh page with shift+reload.
    With Ipad/Android you can swipe feature list in and out.
  • LumenLumen Member Posts: 16 ✭✭
    Thank you. Browser zoom is'nt it, though it must be this browser. I can see the list on other machines, not this one that I have been using for the last few months.
    Ok, So I found it !.
    Somehow it had collapsed to a small thin rectangle looking like a menu divider.
    Small little tidbit/trick about this using chrome.
    In Chrome you can find the locations of dialogs in your resources tab of your developer tools, listed under local storage.  If you were to remove these entries, the dialogs will move back to their default location after a reload.
    Jake Ramsley
    Superb tidbit!
    Thank you.
