Introduction to CAD: In-Context Part Design 2
chimdi_mbagwu
Member Posts: 6 ✭
- If I project existing geometry onto a sketch plane, how I do I hide the object I projected from? It is hard for me to see what I have projected.
- What does it mean when the tutorial says on slide 2 "This will require converting edges from the clamp as well as the sleeves around the ends of the rods." (Does "converting" mean projecting? If not, what is "converting"?)
OptionsNeilCooke Moderator, Onshape Employees Posts: 5,426To hide the underlying part, press the "eye" icon next to the part name in the bottom half of the feature list.
The Onshape tool for projecting geometry into your sketch is called "Use", but many CAD systems over the years have called it Project/Convert/Use so these terms are interchangeable.Senior Director, Technical Services, EMEAI5 -
Optionsjakeramsley Member, Moderator, Onshape Employees, Developers Posts: 657I am not 100% sure looking at your image, but it looks like you are missing a small segment in the top right corner of your triangle, the last little edge from the fillet. If you do this, you should get a closed region and you can select that area to extrude-remove and delete it.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com5
Well, @noa Mighty Scribe of Tutorial Instructions, I assume you are an Onshapes master.
Please take a few minutes from ruling justly over the Onshapes domain to answer another of my lowly questions:
You (or one of your underlings?) wrote in the instructions to project the edge of the clamp in order to remove material and give the clamp a slant. For some reason, I cannot select the trapezoid-shaped area in order to remove it. When I try to select it, I end up selecting a larger region.
This picture shows what I am referring to.
I see what you are referring to, but I don't know how to extend the line to the edge of the fillet.
So we have a sketch that looks roughly like this. I have moved the camera off-center a bit to show that there is a gap missing.
First option would be to use the use command, and select that edge. This will project the missing area into the sketch, such as below (apologies for the colors making the highlight harder to see).
At this point, you can see there is a bit of different color/greying where the triangle is. This means that the region is closed and a region has been created. We can now select this region and extrude it to give us our cut. Since there is only one region, we can select it by either selecting it in the graphics area or by selecting the sketch feature in the feature tree.
The other option, would be to extend the line that is already there.
Choose the extend tool
Select the line towards the end point you want to extend. Both the line and the end point should highlight yellow. Move your mouse so that the new point is on or beyond the point you want to extend to. The tool will find the nearest point/intersection and extend to that. If no intersection, will extend the line to where you placed the point.
See how the region is fully enclosed.
The difference between the two is one creates a second line that is a projection of the filleted curve while the other extends the line and only one line is created. It is very negligible difference in this case, however if you were to go upstream and delete the filleted section before you sketch, the second line would fail with the projection and still succeed from the extend.
