Connect Extrude to Spline Revolve (with a Loft)
tilman_liero
Member Posts: 2 ✭
Hi,
probably a newbie question but I'm stuck and the search did not help either...
I have a kind of bowl I created from a spline that I revolved and thinckened afterwards. In this bowl there is a vertical platform that was created by simply drawing a rectangle at the bottom and extruding it.
Thanks for any help! The document can be found at
https://cad.onshape.com/documents/b7d6d4ac153f4002984b8831/w/634faeec6ce042cd85aaaaa3/e/d2e9440b14894c32aad39a99
NeilCooke
Moderator, Onshape Employees Posts: 5,932
Hi Tilman - you can use the delete face feature on the thin vertical sides of the wall. You could have probably also drawn the wall vertically on the right plane then extruded it in both directions "up to part".
Senior Director, Technical Services, EMEA5
