Is there anyway to "group" text
I created some text to extrude onto a part. Each letter is a separate part. Is there anyway to "group" the letters into words?
If you are extruding text as new parts then their will not be any contact between each letters in text so they will be in different part.You can group them in assembly by using group option
Usually such grouping would be made so that each group exist in their own part studio and then you derive them in main part studio. I'm not 100% sure if this will work in your case.
If you wan't to try, tip for positioning is to create mate connectors in each studio and use transform by mate connector in main studio.
