can you rotate text
I want to rotate the text in onshape
gideon waldner
viru Member, Developers Posts: 619 ✭✭✭✭
@gideon_waldner722 , Yes we can rotate text in Onshape sketch. You have to delete horizontal constraint in text and give dimension to one point after that you can rotate text. Kindly refer below video for more detail.
5
Click "show constraints" in the sketch dialog and delete the horizontal constraint shown on the textbox. You may have to fix one corner of the rectangle but then you'll be able to rotate it, and add a vertical constraint afterwards.
