can you rotate text
gideonwaldnergideonwaldner Member Posts: 32 EDU
edited January 2016 in Community Support
I want to rotate the text in onshape
gideon waldner
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,912 image
    Around a cylinder? No, sorry. Please use the feedback tool to request it as an enhancement.
  • gideonwaldnergideonwaldner Member Posts: 32 EDU
    edited January 2016
    No i want the d to be on top so it it spells dewalt from the top to the bottom like this one
    gideon waldner
    @gideon_waldner722 - you really need to work on being more descriptive in your posts!
    Click "show constraints" in the sketch dialog and delete the horizontal constraint shown on the textbox.  You may have to fix one corner of the rectangle but then you'll be able to rotate it, and add a vertical constraint afterwards.
    @viru thanks it worked out
    gideon waldner
