SimSolid
colin_daly
OS Professional Posts: 40 ✭✭
With the trial of SimSolid I expected to be able to run a test analysis. Now I've gotten the message that I cannot do so in the demo version... is this how its supposed to be?
I have used Simsolid since the beta. You should be able to use whatever model you want with the trial. What is the message exactly?
Paul
The standard version of SIMSOLID is limited to 150 parts and 8-cores. Go over that and you can still manipulate the model in the UI but cannot analyze it. This puts the product in demo mode.
If if you need to process a larger model contact us and will can discuss.
Regards,
Ken
SIMSOLID Corporation
twitter: @ken_welch | web: www.altair.com/simsolid
Just tried your app for the first time, I found it very easy to use and had result within the 1st hr on 130 part assy so was suitably impressed. So much easier and quicker than other methods I have used.
I then loaded some linkages in to connect to the main part but can not work out how to add pin joints. Is this possible?
Paul
