Is there a glossary of terms used in Onshape?
Hello
I am new to all this and words like "Feature" and "Sketch" have very precise meanings in Onshape. Maybe it could be broken down into:
a) A list of common engineering terms (e.g. boss, fillet)
b) A list of common geometry / parametric geometry terms (e.g. co-incident, Normal, Perpendicular, + basics like: Face, Edge, )
c) A list of common CAD terms (e.g. Extrude, Sweep, Loft)
d) A list of what Onshape-specifically means by any of the above. (e.g. Use [tool], Sketch, Part, Model... )
Thanks
J
Thanks
J
That is a useful list of shortcuts. What I was looking for was a formal definition / description of what each term actually means.
P.S. Ah I get it! That very first shortcut [shift]+[?] is the possibly most useful... ;^)
Where can I find a glossary?
Also see http://www.microsystemsgeorgia.com/cnc.htm
https://forum.onshape.com/discussion/comment/6965#Comment_6965
However what I want most is a Onshape glossary, that defines exactly what Onshape means by each word. i.e. A short description of how each concept is used in Onshape and how it fits in so as to create a model.
e.g. Profile
e.g. Document
e.g. Feature
e.g. Sketch
e.g. Constraint
e.g. Part, Component, Work Plane, Draft, Assembly, Drawing, Body...
...These are words that any English speaker half-knows what they mean, but we don't know exactly how they are used in Onshape.
If I could find a free wiki that could be used for the purpose it would be tempting to build one myself, as this would be a great way to learn!
e.g. Something analogous to this wiki site for shortcuts:
http://www.shortcutworld.com/en/win/MyLifeOrganized.html
except focusing on jargon.
ASIDE: I find it ironic at best, that for an "in-the-cloud-everything" tool like Onshape, I am now resorting to an off-line copy of their glossary which I have now resorted to turning into dead trees !
I hate when the english word is translated into spanish in 3 different ways.
Btw Onshape will be the first 3D CAD system that can translate properly the command "circle" into Spanish as "Círculo" (instead of "Circunferencia").
Well... On second thought, the command should be called in English by its correct name: Disk ;-)
- Part Studio
https://cad.onshape.com/help/index.htm#search-part studio
also download the attached PDF file of help from below link.
https://cad.onshape.com/help/PDF/Onshape.pdf
Although a list of key terms, complete with nice short (not overly technical) descriptions is in some ways more useful.
I have printed out the glossary of terms - which is short enough to print out and annotate by hand.
the tutorials and videos are nice for learn-by-example, but at this point i really need to better understand the overall model of how everything fits together.
