creating a dome like profile
hey guys, im trying to mimic a design aspect from a part. But im not sure the easiest way to do it.
Its the rounded fillet or chamfer around these bolt holes.
What i have so far is this,
Whats the best way
Whats the best way
NeilCooke Moderator, Onshape Employees Posts: 5,904
HEY @jakeramsley - get outta my posts!
This is an approximation, but it was easier to do this than explain in text: https://cad.onshape.com/documents/47dff486a76348e394456ab7/w/81feb7d34ecf47e7b75b1bd7/e/430457fb95514ce9af820542Senior Director, Technical Services, EMEA5
Anyway - create a plane through the axis of the hole and sketch a triangle on one side representing the area to remove and revolve/remove. To get that exact geometry on screen would require you to do one boss as a separate part, then pattern/mirror and combine them later (this would also get rid of the slither cut-out).
