Auger Creation - Can anyone do this in Onshape
brucebartlett
Member, OS Professional, Mentor, User Group Leader Posts: 2,148 PRO
Hi all, I have a requirement for a design with an auger. I really want this to be a para-metric part done in Onshape, however I can't model it. Currently I am using a imported part and adjusting with a move face command but it would be better to have it built from scratch in Onshape with variables. Has anyone got idea's how to achieve this.
see layout geo at:
https://cad.onshape.com/documents/35911b0d72b3496386b77be7/w/35662bd64d0f4167b8e6de73/e/59db176b8c03493398222b82
see layout geo at:
_Ðave_
Member, Developers Posts: 712 ✭✭✭✭
@brucebartlett here you are
https://cad.onshape.com/documents/3f8e994167444ff5951a9b32/w/b40ae7737693490ba889b6e4/e/b2ed0ce56ba84d48914fec59
Just add variables.
_Dave_
6
Just add variables.
_Dave_
Sketch the center "post" and extruder it to the desired length (Variable 1), create a helix around the center post with the number of rotations or pitch desired (variable 2), and then create a plane at a curve point and sketch the dimensions of the profile to sweep around the helix. You could tie the dimensions of the profile to variables as well to make it very fast to modify all the way around.
Hope that helps.
