Who's watching?
in General
While working on private documents in OnShape, every once in a while I'm seeing an indicator appear in the upper righthand corner of my document window signaling that an OnShape employee/consultant has opened the drawing I'm currently working in. The indicator quickly goes away, but not before I'm able to mouse over it to see the user's name.
Can somebody help me understand why this is happening?
- Bob
- Bob
_Dave_
who's the user's name?
_Dave_
You can remove share permissions from anyone (including support) from the Share dialog.
but, no, I haven't explicitly shared the document with any one. I'll confirm sharing settings when I return to my next.
Are you sure it is not just you and somebody else ? In any event you can just open a support ticket with the documentId in which you have this problem mentioning the time you had this issue and Onshape can see if there has been any unauthorized access
It is much more likely that you are 'collaborating with yourself'.
As Philip said, we take the privacy of your intellectual property very seriously. There really are no tools that will let an Onshape employee open a private document unless it has been shared with support.
- Bob
Moreover, the screenshot is optional and there are even tools for blanking out specific areas of the screenshot.
Bottom line - your private document is exactly that - PRIVATE
I want to say to everybody reading this posting that I'm comfortable with the explanations I've received related to this issue and impressed with the team's workflow, support and response. I'm also glad to hear that the team's already developing an alternative means to check the status of user documents that protect confidentiality and mitigate users' confusion.
Thanks.
- Bob
@john_rousseau you might want to consider implementing something that automatically unshares the document when a support ticket is closed.
Once a week we run a script that automatically removes support from shared documents that no longer have an open ticket against them.
I have sometimes bumped into Onshape support (real person) working on my document (which I have shared to support and I'm glad they actually open these and try to help). They usually 'run away' really fast, I suppose that's the policy not to disturb me working.
Actually sometimes I would like them to stick around and maybe even follow to see if they can reproduce some anomaly I have reported.
But even more, I'd like to have simple chat to say hello and maybe say 'I'm only here to check one dimension, you can continue troubleshooting' - or 'I need to work, can you please come back later? '
What are these "file" things you speak of? :-)
I think it's one of the great benefits that Onshape support can troubleshoot exactly the same situation where problems occur - I've always hated when sending copy of trad.cad file to support and get update after a week or so that everything was ok - no problems found on that file.
LOL
