importing an assembly and Parts
mark_biasotti
Member Posts: 123 ✭✭✭
I have a question: If I want to import a SW assembly Naturally, I must import the parts and the SW assembly. 1) does OS even recognize a SW assembly file with or without it's associated parts? 2) with a large imported assembly, how does one organize it's many parts into one "location"? and 3) associate it with the imported assembly? OS allows you to import a SW assembly, but once it is imported/uploaded, and you try to open it, nothing happens - probably because none of it's parts were uploaded with it. So to summarize, what is the best workflow for importing a SW assembly and having all the imported parts and assembly logically organized?
Mark
Addition: So I have discover from Joe D. that import of SW assemblies is not yet support and that we should rather import it using Parasolid. So if this does work (importing parasolid assembly) my question still stands; how does one logically and conveniently organize an assembly of parts? I guess this is actually a much broader question and if there is a tutorial of this I would appreciate watching it and learning. It is, I would imagine, an important topic and would love to see a webinar on "how to transition from file-base MCAD to Onshape file management?"
Mark
As far as I know, OS can only translate SW parts, not assies.
STEP will also work, but for SW: Parasolid > STEP.
Saving your SW assy to Parasolid should be very fast.
Dries
A drawback with translating to OS part studios rather than an OS assembly is part studio's don't support multiple part instances so the same part comes up as a different part in the part studio.
It will be nice to getting referencing for parts and assemblies across multiple OS workspaces, I don't want to have to translated common parts numerous times into different Onshape doc's.
It would also be nice to get the parts meta properties from solidworks, eg no retyping or cut and paste.
https://forum.onshape.com/discussion/245/working-with-imported-data-webinar-recording#latest
Let me know if this helps
We are hesitant to invest too much time or resources a current behavior that is going to away soon. We will directly handle SW assemblies.
We are hyper aware that there are areas we need more material and more information. So the more you let us know where you find gaps the better. Its where we are spending quite a bit of resources. And will continue to do so.
Joe
mark
This is an area I am spending a lot of time on various scenarios and we know it is important to get right and get out there prior to production... Probably off topic in this discussion.
https://forum.onshape.com/discussion/11/folder-in-my-documents#latest
