Different radius fillets in a single fillet feature
robert_zschocherobert_zschoche Member Posts: 17
Can I have multiple fillets with different dimensions in a single fillet feature
  • robert_zschocherobert_zschoche Member Posts: 17
    I intended for this to be a question.. not sure how to change its status in this forum
    "Shift +enter" will finish the current fillet but keep the dialogue open for your next fillet if its speed your after. But you will still see multiple fillets in the tree.
    edited July 2015
    Thanks. the productivity piece is good, I'm just looking for ways to keep the number of items in the tree to a min.  The tree can get busy especially without the grouping function.  Thanks for the input
    @robert_zschoche If you were after variable radius fillets, you can brute force it with lofts.
  • 3dexter3dexter Member Posts: 89 ✭✭✭
    +1 variable radius fillets.
  • john_smith077john_smith077 Member Posts: 175 ✭✭✭
    robert_zschoche Please can you tell me what steps were involved to generate that variable radius fillet albeit using lofts.
    +1 Variable Radius Fillets
    +1 Variable radius fillets
  • tsung_ren_hungtsung_ren_hung Member Posts: 9 EDU
