Can I make a shape in sketch 1 and copy&paste it into sketch 2?
david_cushing
Member Posts: 16 ✭
I want to make a shape in my first sketch, copy it and extrude. Then I want to paste that sketch in to my second sketch, maybe even alter it then do another extrude. Is this possible? Or should I just start sketch 2 with sketch one visible in hopes of being able to trace the exact shape again?
jakeramsley
Member, Moderator, Onshape Employees, Developers, csevp Posts: 669
Yes. While in the sketch, select the entities you want to duplicate, right click and choose 'Copy sketch entities' from the context menu. After this, open the sketch you want to paste them into, right click, and choose 'Paste sketch entities'.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com5 -
shashank_aarya
Member Posts: 265 ✭✭✭
@david_cushing Yes it is possible as shown below
Even if you alter the shape of first sketch after copying the sketch entities, it will take original sketch entities after paste operation.5
