Issue Resizing Part
Hi,
I have imported a Part into Onshape, then created a new sketch of the part. Meanwhile, I am having issues resizing the part. Selecting the Dimensions Button does not enable the feature.
Thank you.
Joseph
_Ðave_ Member, Developers Posts: 712 ✭✭✭✭
Looks like all that you have done is defined a sketch plane on the face of the part, As of yet there are no entities to dimension. Even if you created lines constrained to the edges of the part you couldn't re-size the part by redimensioning it. You would need to learn the direct editing tools (move, delete face etc.) to change existing faces. If you can define specifically what you wish to accomplish I may be able to help.
_Dave_5 -
NeilCooke Moderator, Onshape Employees Posts: 5,873
The sketch dimension tool will only resize sketch entities. If you want to resize an imported part, take a look at the direct editing tools - move face, delete face, replace face.Senior Director, Technical Services, EMEA5
Thank you. Isn't possible to resize it using the Dimensions Functionality found in the sketch design?
_Dave_
_Dave_
I have tested the functionality using a newly created sketch (a non-imported 3D part as in the previous case) in the same document and everything is working properly. I believe that there must be some constraints existing on the imported part, which prohibits me from modifying its dimensions.
I you share a link and explain what you are attempting to do, I'll have a look.
_Dave_
https://cad.onshape.com/documents/1c1bd57501f058d79fd4d193/w/fe93ebe587bc64ea153ecd07/e/e64b7a3a00b5f3537703a606
Thank you again.
Joseph
_Dave_
Joseph
