View Dimensions
When I as to View Dimensions of a feature (extrusion) all I get is the sketch dimension, not the extrusion length.
Am I missing something?
Are you after screenshots with dimension or just wan't to know some measure/distance?
I have asked for advanced 'named views' with possibility to add visible dimension since I would need to share these images. But if you just wan't to check some dimension, click any edge and see the measure in bottom right - click another instance and you will get distance and other measurement info.
When asking to show dimensions one also has the opportunity to select a dimension and revise it, although when selecting the dimension you are brought back to the sketch and have to re-select the dimension to revise.
Without being able to see the extrusion dimension I have to go back to the extrusion in the feature list to bring up the dialogue box.
I feel this is a bit cumbersome.
I'd rather be able to revise on the model. Would be much quicker.
