add a note/comment to end of dimension on a sketch
Josh_Bond
Member Posts: 6 ✭
Is there a way to add a note to the end of a dimension on a sketch? I tried all the brackets, paranthesis, etc. The text tool is too much hassle & bulky.
NeilCooke
Moderator, Onshape Employees Posts: 6,004
No you can't add text to a sketch dimension but you can in drawings, or you can add a comment and tag a piece of geometry. Depends upon what you are trying to achieve.Senior Director, Technical Services, EMEA5
30 mm / #struts /* This is the distance between the struts. */
