"Onshape" button in Maxwell Render?
lowjacklowjack Member Posts: 14 ✭✭
edited February 2016 in App Store & Partners Apps
So I've downloaded Maxwell Render and tried following the steps in the Feb 3 blog post "Introducing Onshape for Maxwell Render." But the problem is that I see no "Onshape" button in the studio anywhere. I can't find anything that would let me use Maxwell with Onshape at all.
 What am I missing? My window is labeled "Maxwell Render - x64" and does not look like the screens shown in the blog post. I'm running Windows 7, 64-bit. Any ideas would be most appreciated.
  • michał_1michał_1 Member, Developers Posts: 215 ✭✭✭
    You should have also that file "maxwell_onshape_connection_win64.exe", run it and On button will appear.
  • lowjacklowjack Member Posts: 14 ✭✭
    That did it, thanks. It also looks like Maxwell Render and Maxwell Studio are two different animals. I guess it helps when I run the right software. :)
    Right, but for some reason, I have separate icons to launch each one. Naturally, Windows chose to place the icon for "Render" on my start menu first, so I used that, rather than looking for the actual program folder and finding the appropriate icon. (I'm not the most tech-savvy person on the planet)
