No idea how to crack this one... bending an extruded shape.
 maciej_janowski
                    Member Posts: 2 ✭
maciej_janowski
                    Member Posts: 2 ✭
                    Hey,
I'm creating a model of a glasses frame, because my old one broke and I want to 3d print another one. All was well and good, but I have no idea how to give the lens holders a slight bend (that is present in original glasses and required for the lenses to fit).
https://cad.onshape.com/documents/a3f0189fd0590ed5b048b859/w/d6ab1656c8a5077ba51f786d/e/bc2ec22564ac7477e28a6d3eb
Here is the document I'm working on. Any ideas?
Edit: looking at the part, for those frames a better approach might be to create a curved surface (could be a large cylinder perpendicular to the frames) and split it with an extruded surface. Then you can thicken the split face.
Here is a rough version of what I mean: https://cad.onshape.com/documents/56bd1beee4b0dc9b60c1ec11/w/7c01a20745ae9cdd06a4504b/e/00542765310bc15f83b3f8b3
Of course modeling the curve to match the lenses might be a bit trickier than a simple cylinder...
1. Create a surface that represents the curve you are looking for. I sketched a curve on the front plane and extruded it in both directions.
2. Start a replace face command
3. Select the face you want to bend for the face to replace. Select the surface for the surface to replace with.
