Connecting multiple instances of the same part in an easy way
baumarbaumar OS Professional Posts: 78 PRO
edited February 2016 in Community Support
I try to connect multiple instances of the same part.
The most simple example I can think of is a set of 10 equal lego brick that you connect to build a wall. Or even simpler just a rectangular brick put in top of each other imagining they might be glued together in reality.
Each brick comes from the same part and you add them just one in top of the other.
I inserted to instances of the part and connected them with the fastened mate by selecting a top and a bottom layer of each part. That works.
Then I added another part and added it again with fastened mate. Since there are many, that takes an awful lot of time and I think there must be smarter way.
I also grouped the 2 fastened parts, grouped them, copied and pasted it and joined them again using a fastened mate. Then I group the 4 elements and do the same. That works, but still I have the feeling there must be a smarter and more efficient way.
Thanks for help
Markus
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,873
    Have you tried Snap Mode?
    Hmm snap mode, what's that?
