how do I insert Onshape sketch into Draftsigtht?
jackie_1
Member Posts: 20 EDU
When I inserted my Onshape 2d sketch into a Draftsight template, it did not get put it in the same layer. Did I do something wrong?
NeilCooke
Moderator, Onshape Employees Posts: 5,923
Hi Jackie, you probably needed to set "cut" as the current layer in DraftSight before importing the Onshape DWG. Onshape does not have layers so you can't do it upfront. See this link to move the objects to another layer (it is AutoCAD but should be very similar): http://www.cad-notes.com/3-ways-to-move-autocad-objects-to-other-layer/
Senior Director, Technical Services, EMEA5
