how do I insert Onshape sketch into Draftsigtht?
When I inserted my Onshape 2d sketch into a Draftsight template, it did not get put it in the same layer. Did I do something wrong?
NeilCooke Moderator, Onshape Employees Posts: 5,848
Hi Jackie, you probably needed to set "cut" as the current layer in DraftSight before importing the Onshape DWG. Onshape does not have layers so you can't do it upfront. See this link to move the objects to another layer (it is AutoCAD but should be very similar): http://www.cad-notes.com/3-ways-to-move-autocad-objects-to-other-layer/
Senior Director, Technical Services, EMEA5
