I agree too and same ignorance applies to resellers.. sad but true
I would also like to be able to add parameters to parts, assemblies and drawings and then be able to access those in drawing titleblocks and tables. For instance, I would like to create a table for an assembly that would populate with parameters like Part Number, Description, Specification and Material/Vendor.
I suppose your after BOM (bill of materials), there is something for this in appstore - but I agree that we should be able to add bom into drawings as well.
I'm new to OnShape, but I love the concept! Since I'm a serious Linux user, I now finally have a CAD system that I can use without Virtualbox! Very cool.
The modelling part of Onshape is pretty good, although I've yet to do real complex stuff. The part that missing for me is the documentation portion of Onshape, i.e. making drawings and other documentation to communicate design concepts to suppliers, customers and so on. I agree with the list of brucebartlett, in particular the transfer of meta data from model to drawing, the ballon linking to parts and BOM, and the export and import of BOM.
Cheers!
Hagen
OS Drawings needs to mature to the point that Drawings has (as an absolute minimum) all the functionality of Sketches, plus rendered views from any viewpoint, etc, etc. For this reason I cannot yet use OnShape as my go-to production tool, as much as I like the modelling environment!
I'd like the to show the bolt circle in a drawing so it can be dimensioned. The circle is drawn in a sketch, and then hole features are patterned. How do i do this?
Also, is there a way to show countersink dimensions in the same note as a hole diameter for a countersink created with the hole tool?
You can checkout my example part/drawing here:
https://cad.onshape.com/documents/973f6a750c5f7719fb9dd558
