Parallel mating query
I have attached an (extremely crude) image to better explain my query.
Imagine that the 2 parts are sheets of metal extruded down into the page. I am trying to maintain the parallel distance, achieved using a custom mate connector but mate the other two faces as indicated. Again, apologies for the crude image.
I have followed your demo exactly as above and it is almost there. The only difficulty I have is that the planar movement in your demo i.e it slides in the direction of the offset does not seem to work for me, the blue item only wants to slide along the length of the yellow one rather than away from it. If I could get that worked out then I'm sorted here.
The trick with this methodology of using high-level mates is to always think about which degrees of freedom (DOF) you want to exist.
In order (of mate connector based mates) of increasing DOF
Fastened - 0 DOF
Revolute - 1 rotational DOF
Slider - 1 translational DOF
PinSlot - 1 translational DOF
Planer - 2 translational DOF
Cylindrical - 1 translational and 1 rotational DOF
BallSocket - 3 rotational DOF
The benefit of this system is that it will typically take fewer high level mates than the same mechanism created with low level mates.
Have to say, loving the community and onshape in general. Excellent guys.
