Firefox crashing whon opening a project.
Hello,
I recently swithched to Linux and since then I experience Firefox crashing. I know there was a similar question, but deleting prefs.js didn't help either. I have no problems running Onshape in Chromium and the Khronos WebGL demos work perfectly fine, even in Firefox.
The  compatibility check gives the following log, if it helps:
{"coreWebGL":"Supported","is32BitIndicesAvailable":true,"isAnistropicAvailable":true,"isFloatTextureAvailable":true,"rendererInfo":{"glVendor":"unavailable","glRenderer":"unavailable"},"userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:44.0) Gecko/20100101 Firefox/44.0","browserSupported":false}
Is there anything I can do about it, because I'd really prefer to use Firefox?
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015 image
    Please do not post crashes here in the forums since they are typically client related and require us to take a look closer at your situation.  Please use the ? menu -> Feedback to send in a ticket so we can look at the issue.  On the cad.onshape.com/check site, which of the checks failed?
